Hi im having troubles with my motor it was having trouble going into gear then started jumping like the clutch dogs were gone but when it is under more power then 1500rpm no more jumping i then adjusted the cable and it selected forward fine but then it had trouble getting into reverse then would get reverse but not forward then forward was fine i have a clicking noise when in neutral out of the water if you spin the prop and if the motor is running and i put my hand were the cable goes it feels like a ticking so my question is is this the shifter linkage can it be an adjustment some were it almost feels like the shaft going down to the lower unit maybe lose making it not engage properly any help would be great
