I have a 1982 Evinrude 25 hp. the shift lever was frozen. I got it freed up and now it turns but the upper linkage isn't moving. How can that be?? I have already removed the lower unit. and the upper linkage can be seen thru the oval hole. when I turn the shift lever the linkage stay put-not even trying to move. Unless the shift lever is broke right in half, how could the upper linkage not move? What do I have to do to get the shift lever out? Your help is greatly appreciated.
1982 Evinrude 25 model # E25RCNB
