marauder11
- Oct 10, 2011
- 176
Just got a new to me outboard. Seems pretty easy to operate. I have a 1986 120hp Johnson and it has a tell tail for the cooling( might be wrong name but has a stream of water to show the impeller is moving water). This little outboard does not. A few questions. Will I be able to tell if its moving water? If not how easy is it to install one? Also will installing a tell tail on such a small motor affect the cooling? i would hate to over heat this. If anyone has one with the tank on the leg how long cam you troll around on it? Any idea how big the tank is?
Thanks
Thanks
