1975 Evinrude 9.9 model 10554C electric and rope start. Just want to verify (before I torque down the flywheel) that I static time on the ?E? markings on the flywheel There are 4 marks on the flywheel. ?E? and ?R? on one side and the same thing 180 degrees on the opposite side. The letters are raised on the flywheel. See attached photo.....
First time ?tuning up a outboard? and I also would like to know if I should put a small amount of anti seize on the threads that the flywheel nut goes on?
