phillnjack2
Ensign
- Apr 30, 2011
- 918
Ok first off I have the 1995 model 3 cylinder evinrude
gear ratio is 2.42 to 1.
the engine is longshaft with the newer multi spline main shaft from engine to gearbox and that will NOT be altered .
I know some of the older model came with a 4 spline shaft,but this is the later version.
My question is this.
can I change the gear ratio to 2 to 1 by using gears from the v4 engine ?
I have the gearbox that looks almost identical to the v4 crossflow as in size etc, and the thru hub exhaust is around the same diameter.
I am wondering if the actual gear set (F-R) could be changed to give me a 2 to 1 ratio.
this would allow me to have a faster spinning propeller and thus allow me to run smaller diameter props.
would the actual gear shaft allow for the different gears..
