Classic Ski-Boat
- Feb 1, 2010
- 16
Hello everyone,
In 2010, with a great help of this forum (thank you guys again), I managed to replace my impeller and solve some water pump issues. Since then we have been using our boat/engine approximately 5 times per year ? no problems, water pump working and always (at all speeds) pumping water out of the outlet/exhaust on the top of the leg. I would estimate the engine use to be 10 engine hours in total - engine always flushed in a deep bucket after each outing.
Last week we went on holiday and left our boat on a mooring (salt water) for 5 days without the ability to flush the engine for 5 days. We left the engine leg down, in the salt water ? this was recommended by some other more experienced boaters than we are.
The engine was running fine but on the last day we noticed that at higher speeds the engine didn?t pump any water. At 5 knots it would pump water again but going any faster resulted in no water coming out at all. We tested the engine in neutral, in high revs and water was coming out again. Then going in-gear in high speed/revs, no water out. We stopped boating because we didn?t want to damage the engine.
The next day at home I flushed the engine several times in a bucket, low revs, high revs (in neutral) and the water was pumping again. I am not sure what to think about it now but I think that we still have a problem.
A couple of questions:
1. Is this a salt water and not flushing for 5 days problem?
2. Is it some different high speed/in-gear/water pump problem?
3. When next time on a mooring ? shall we keep the engine leg down (in water) or up (out of water)?
4. After how many engine hours should we expect to replace the impeller?
5. Do you have any recommendation regarding extended salt water use without the ability to flush each day?
Any suggestions and comments will be greatly appreciated.
Thank you.
Thank you.
