Tinker Mark
- Jan 30, 2014
- 5
My motor worked fine, until I replaced the H2O pump. The motor won't go into reverse now & once shutdown it won't restart because the 20amp fuse is blown. If I replace the fuse it will start again but still not shift into neutral or reverse once shifted into forward. I tested the shift solenoids & both tested @ 5-6 Ohms, any suggestions?
