I have read a ton of threads on this and I just cant seem to find exactly what my problem is. I have a 1984 evinrude with the power tilt trim. With the switch I can run the motor up, but when switching down all I hear is the relay clicking. I replace both relays and still have the same problem. I checked connections and all are good. I replaced the fuse in the relay box as well. I also skinned back the blue and green wires before they enter the motor itself. When the switch is engaged I have 12v to either blue or green depending on direction I have selected. Motor is stuck in up position, and will not go down at all. Still tried to go up when I select up so i know power and motor is working. When I select down all I get is clicking on the down relay which is new, and I have switched out with up to make sure. Any Suggestions?
