Drowned Rat
- Jan 20, 2004
- 3,070
Good morning iboats family,
I picked up one of these beauties yesterday and had a question about the carb bowl. The previous owner said that there was fuel leaking from around the glass bowl, so he went to change the gasket that sits above it, but instead of buying the right one, he made one from cork. Now it won't run. When you squeez the bulb with this cork gasket installed, it is very difficult to get the bowl to fill. Does this also mean that the fuel is likely not reaching the cylinders? Becuase the gasket is cork, or perhaps wasn't cut to exacting specs?? I presume it may be blocking the outlet passage to the carb.
Any help with this one? BTW, this motor has had a properly converted fuel pump.
Thanks so much!
Thanks so much!
