Started my 85 Evinrude motor today for the first time since last summer. The motor started but ran rough as expected for the first start up. I ran the motor for about 5 minutes and the motor ran out of gas. Put gas in it and got the motor restarted but it did not want to stay running. When it didi start it ran for a 30 seconds or so and then died. I first suspected a fuel issue but I put a spark tester on several plugs and there was no spark. After the motor cooled down for about an hour I turned the motor over and the spark tester showed a strong spark and the boat started. I quickly killed it and put water to the motor (taking about 5 minutes) and when I went to restart it, there was no spark. Any ideas? There is no spark at any cylinder.
Thank You for any hep.
