1961 Starcraft
- Jun 26, 2011
- 11
I have the skeg off on my 59 Johnson and i would like to know how to remove bearing number 39 in the diagram it is the one under the pinion gear. I have the gear out but need to replace the pinion bearing as there was metal in the gear oil and no other gears/parts were deteriorated or grinded off. The link below is the diagram. Also any installation tips would be much appropriated.
Thanks
http://www.*****************/parts/...1&manufacturer=Johnson§ion=Gearcase+Group
Thanks
