Re: evinrude will not idle up
Not likely IF the engine runs Ok otherwise. How does it run? All the way up to WOT, strong?
If so, unlikely a bad timerbase.
If you determine the timerbase is OK, I would check very thoroughly the complete link and sync procedure.
Make sure all butterflies are closed completely, etc.
What is it's idle speed now?
