So I started pulling apart one of the 8, starting with the only one I actually wanted... And...
Compression looks good! 82psi per cylinder! Let's get this motor running!!
Obviously I need a carb kit and there's hardly any plastic left on the coils so I'm going to need coils and probably best at the same time to do new points and condensers too.
The parts that worry me are in the LU... I dropped that and inspected the water pump (impeller didn't look bad but I might as well get a new one anyways) and the housing is pitted. Should I be worried about pitting in this? Also, the driveshaft was pretty dirty but when I pulled it out I noticed a worn groove right around where the oil retainer sits. It's nothing deep but should I be worried about this as well?
