Greetings,
I?m rather new to the Forum and to Posting and am seeking advise.
I just rebuilt a ?51 (or was it the ?52?. I can?t recall at the moment) Evinrude 3HP Twin Cylinder (all new electrical and carburetor rebuild) and was absolutely amazed when I went to start it on how easily it fired up. When I rebuild these older Evinrude/Johnsons I can get them running pretty well but have never had one come to life so easily. My normal practice is to gently and slowly pull the rope through a couple of cycles before I ?sharply Pull? to try a start. This engine was running on the first ?gentle pull? before the rope was even halfway out.
Wishing to better understand the starting characteristics of this engine, and hoping to bring the same ease of starting to my other motors, I started the motor 3 dozen or so times over the next several weeks, no more than twice a day and always going 3-4 hours between starts. Each time I would run the engine at idle to full throttle and back for no more than 5-6 minutes, tops. What I found was that after the first couple of starts, each start began to get progressively harder until now I?m back to a normal (for me anyway) of 2-5 strong sharp pulls to get the engine to fire. Once it fires it runs great.
My question(s) to the Forum members are: What happened? And how do I get the ?easy starting? engine back and maintain it longterm?
I?m guessing there is something changing in the fuel atomization.
I just installed a ?rebuilt? ?61 18HP Evinrude into my recent boat project (a Ken Hankinson designed Ultra Pierre) and it is a terrible starter (even with electric start). I?m hoping to gain wisdom here and incorporate any suggestions into that engine as well as some others I use during the winter months in Duck hunting and Steelhead fishing boats.
I would truly appreciate any and all ideas/suggestions.
Thanks,
Mike
Thanks,
Mike
