Hey guys,
I had my 1991 9.9 johnson running at the house, hooked up to the hose and running fine.Motor was pissing water fine, I turned up the throttle a little and all heck broke loose. It made some bad clanking noise. So, I hit the kill swithch right away. I was looking in to the noise and found a broke spark pulg in the lower piston and the motor would spin. So I put it away knowing the motor was a loss. Then I looked at the motor the other day and the flywheel spins. however, it get to one point and is really tough to spin. Any ideas what happened? Is it worth fixing?
Thanks for your help,
zboats
zboats
