1994 Evinrude Ocean Pro -Tilt/Trim not working
Luvtofish123
The tilt/trim on my '94 150 Evinrude Ocean Pro stopped working. Does not work from Engine or Throttle. I have 12v to the relays. If I pull one relay and jump from the 12v to the tilt motor wire it goes up. If I put that realy back and pull the other relay and jump the 12v to the other motor wire it goes down. Does anyone have a wiring diagram for this,or ideas on a fix. It's obviously not the motor, I am doubting that both switches or both relays would fail at the same time.
alldodge
Re: 1994 Evinrude Ocean Pro -Tilt/Trim not working
:welcome: to iboats
Have a look here, at the bottom you will see trim diagrams
Mastertech Marine -- EVINRUDE JOHNSON Outboard Wiring Diagrams
boobie
Just for the heck of it swap the relays once and see what happens. Also check ALL the connections for any corrosion.
Luvtofish123
:welcome: to iboats
Thank You So much. That Schematic is perfect !
Luvtofish123
I tried swapping the relays. Going to clean the connections and I got a wiring Diagram which is going to help a allot !Thanks for the reply !!
