notactjack
- Jan 1, 2014
- 9
Ok I got this 1973 65 HP johnson. it was partially disassembled so I don't know how it goes back together. I have a manual but it doesn't help. I dont see how the fuel pump is mounted on. Also I can only see one hose mount on the engine (vacuum or fuel inlet). So how do I mount the pump? And where is the fuel inlet and where do I get vacuum to run the pump. If anyone had pictures of the side of the engine it would be awesome. Also I wanted to make sure I had the starter solenoid figured out and then. I also don't know where the relays for tilt n' trim would be or if I have to make my own harness for that.
