norman2013
- Dec 8, 2013
- 154
Hey guys, I have a 1980s johnson 15 hp outboard that runs flawlessly in the summer and down to about 40 degrees but when its colder then that the motor likes to stall out unless i pull the choke about 1/4 of the way out. It also runs fine if i have it full throttle, but when i go to slow down it likes to die on me. I do a lot of duck hunting in 30 or below. Is there any way i can make this motor run better in the cold or am i just out of luck?
