I have a 78 Johnson 25hp that I'm trying to wake from the dead. It's been sitting for 15 years. I've replaced the wiring harness, fuel pump, plugs and rebuilt the carb. I can get it to start then it revs, acts like it starves for fuel then revs again. This is all with the throttle at half or more. With the throttle closer to idle, it cranks, revs and chokes down. If I bump the choke when it chokes it will rev again then choke down. As long as I keep bumping the choke it will keep running but it's up and down. Has anybody got any advice for me. This thing is about to drive me nuts. Thanks!
