Hi,
I have a bit of a wiered problem with my evinrude fitch fuel injection 150 v6 1999, I was on a sea and started the motor and was plaining when the motor started to kick and missfireing, i pulled it up ashore and got it to the garage to diagnose the problem, first i changed the plugs with no results at all, the motor kept working worse and worse it shakes and runs extremely rich of fuel and is starting to pour oil even out of the propeller, then once it was a little dark and when i started the motor i was seeing sparks from the inside the coil bracket to the engine block and the spark continuity was low sometimes from the high tension leads so i decided to change the coils all the 6 of them and found one of the coils that was a little bit faulty as it had a tiny hole so i changed them all, no good results at all even after changing them, i changed all the high tension leads and cleaned all 6 injectors but still nothing and im still seeing some spark randomly and shortly around the engine block and the strange thing is when i pull out the high tension lead out of the 1st cylinder the motor starts to work like nothing has ever happened. Does anyone know what could this be:grumpy:!! thankyou very much
1. spark running outside the high tension around the block.
2. motor works fine again with first cylinder not connected.
3. low spark continuity
