stikshooter
- Jan 16, 2014
- 1
New to the forum, and have a problem. I have a 2000 Johnson 130 that was sitting for about a year. I removed and drained the tank, replaced the filters(water sep. and in line fuel ) Got motor started and it idled fine and would rev up in neutral, but had no power in gear. Tore down the carbs and found trash in bowls, main fuel line breaking down so I replaced it and blew out all lines and fuel rail. Cleaned carbs and orfices with carb cleaner. Installed new in line filter and reinstalled carbs. Motor runs great at top end with lots of power, but will hardly idle now. I can sometimes get it to idle after spraying carb cleaner into intermediate orfice. What do yall think, carbs again?
