Gday all ,i'm after a little advice about replacing the top mount on my motor its appears to be absolutely buggered has actually separated inside ,can anyone tell me how I should go about fixing this can it be done dropping the leg/gearbox assembly or is it off with the power head assembly to get access to this section -any advice greatly appreciated cheers mrbull
