brian5720beth
- Jan 15, 2014
- 3
I had just bought a evinrude junior never had one and I don't know how to start it
Dont put straight fuel in. Mix it 50/1
I cant remember if they a aircooled or not, someone will say.
In the mean time dont try and start it unless the bottom third of the motor is submerged in at least a bucket of water otherwise if it has a waterpump it might burn out.
I think there is a airmix knob in there and a choke and a throttle up the top.
Post a photo if you can. Click icon second to far right in the tool bar on the top of the reply box.
There is probably a on off fuel switch on the side of the motor to you will need to turn on.
Hope you know how to row
As far as I know the ratio was changed to 50:1 long ago.Just run it with any good TCW3 rated oil.
