I have a 1990 40 hp with a bad powerhead. I purchased a 2000 40hp complete short block thinking it would be a easy swap of parts and I would be back on the water... Problem is the front case half of the power has different holes drilled in the casing where the shift parts connect. Can I swap out the case half of the new motor with the old one that has the correct casing holes. I know on other larger engines these are matched pieces but these little 40hp dont have sealing rings between the case half. Anyone have any suggestions?
Thanks in advance
Thanks in advance
