Hey guys hopefully you can help me out. I have a 93' VJ115TLETS. To make a long story short,took my boat out a few weeks ago and she was running fine, then i tried to come in, and it would start no crank nothing. I did some research and first thought it was the neutral safety switch, so i manually started the motor by jumping the solenoid. When i got her to start and the prop was spinning like it was in gear, so i shifted to reverse,forward & neutral, still spun. That led me to believe it wasn't the NSS, it was the shift throttle cables. I'm trying to remove them both the NSS & shift throttle cables to test them, but i cant get the remote assembly off, its a concealed side mount, i have to be missing a pin or screw some were? Since i'm going to be work on that i need help with identifying another part (with the Red Housing) so i can swap it out PLEASE HELP ME OUT..
