i had the engine running, shut off, go to restart and nothing, heard a click. i tested several components and came to replace the engine starter solenoid, but still nothing. any where / thing to look at? - thanks
Re: 1988 johnson 150gt - was running, click, no starter, nothing at all
Check your choke is working, thatl test your power lines.
Try jumping straight to your starter. A click is normally the solenoid working so if you keep hearing the click its possibly your starter or the main heavy wires to it that a bung
