Now that I have the bearing housing out of the gear case. The thing was so stuck it was very hard to get, but with some heat it came out. Now there is some much crud down in the housing it looks like the only way to clean it up is to remove the prop shaft. My book does not cover that only the seal replacement. How do I get the prop shaft out? I really don't want to pull it but it needs some serious cleaning.
Thanks for all the response on my other post.
