williamfw57
- Jan 6, 2014
- 14
Trying to remove lower unit to service water pump,, where do you disconnect the shift linkage to pull the lower unit? thanx
Look for the small hitch pin on the shift lever.--Pull that out and push the shift lever to the port side of the motor.-Almost no tools required.
On my 1990 60HP, I had to remove the starter, loosen the VRO pump and tilt it up out of the way to get enough room to disconnect the linkage.It is about center and under everything.
OK I'll give it a rub thanks
