buzzcatcher
- Sep 6, 2011
- 9
I am in desperate need of some help. Rebuilt carburetor and now have electrical problems... Please advise. Your help is greatly appreciated. Below are the steps I took:
-Disconnected battery cables
-Removed starter solenoid-only removed wire from one end (to reach bolt to remove starter bracket)
-Remove starter bracket-removed positive battery cable (to reach carburetor bolt)
-Rebuilt carburetor (replace gaskets, float, etc).
-Install carburetor
-install starter with bracket
-install starter solenoid (all wires back in original location)
-Connected cable to battery-hand tighten (yes in the correct location)
-connect fuel line and primed bulb.
-Insert key, pressed in and turn
-Heard a click, and heard a zap. Saw smoke coming from my solenoid and a second after saw a spark at the positive battery terminal. Upon noticing the spark at the positive battery terminal, i watched the cable get really hot melting the lead that attached the terminal screw post.
After reading several forums and post, I replaced the starter solenoid, cleaned all connections with wire brush, replaced the battery terminal with a replacement bolt-on style clamp with new terminal post, bought a new wire harness fuse (original seemed ok but replaced regardless). I wrenched tighten cables to the battery to secure connection. Fired it up again and this time, i heard a click, no smoke at all but heard a spark. This time my negative terminal post melted. The wires were really hot.
I am now out of options. Could it be my starter? Is it possible that my starter is bad? If my starter is bad, would it create heat in which melted both my positive and negative terminal post? I am very bummed and do not know what else to do. Can you share your expertise on what is causing my battery terminal post to melt and why my starter doesnt fire the motor? Thanks for your advice!
-Install carburetor
