Replacing a 42 year old Tilt/Trim Motor. I have to re-install the old guts to the reservoir. While pulling apart the old unit, everything stayed intact except two parts. One is a tube or what they refer to as a "valve body can" and the other is a really small zerk fitting about 1/8 inch in diameter. I believe the tube goes over the screen shown on the attached photos. It fits over the screen but I don't see a way to keep it in place. The zirk fitting has me baffled. I see no place that this might go into the valve body or the interior of the reservoir itself. The inside of the zerk is threaded but there is no place to screw it on to. I don't like spare parts so if any of you have ever put one of these thins together, I'd love to get your feedback.
Thanks in advance,
Craig.
Thanks in advance,
Craig.
