Re: Adding tilt and trim to a 1973 Johnson 135
The factory first made a power tilt/trim in 1973, so it is possible to retrofit a factory unit to your engine. 65 thru 135 hp. FR has described it well. I ran a couple of those units and while unusual looking, they worked well. You can find them around, just be sure you get all the pcs. They've been out of production for many, many years-so some of the electronic replacement parts are getting really hard to find. You may find it cheaper to buy a junk engine just for the trim unit.
