I have a 1977 70 HP Johnson outboard that needs a new water intake screen. I broke out the brittle old one. I have the new part but can't seem to get it past the bearing housing. I have removed the 4 bolts holding the bearing housing in place but it won't seem to budge. I have tried putting screwdrivers under it to pry it off, but it won't release. Also, when I do get it loose, will oil spill out if I don't have the lower unit in the upright position?
Any guidance would be greatly appreciated!!!
