Morning Gents,
I was hoping y'all could help me out. I have a 1987 Johnson 30hp and the other i had it running in the drive way and notice it was only running on one cylinder so I checked the plugs and everything seemed fine, even switched the plugs and the same cylinder was dead. I took it out to the river the next day and still on one cylinder at idling but when I give it throttle I can hear the second cylinder try to fire and it kicks a little bit and then engages and runs perfectly on both cylinders until i let off the throttle and it gets back done to an idle and then the same one dies again.
thank y'all
thank y'all
