I have recently bought a 1984 venture bass boat with a 150 hp Evinrude. When I test drove it seemed to run fine. I took it out about a month ago and today. Both times the motor would bog down on acceleration and a couple of times it even died. Supposedly the motor and carbs were rebuilt within the last few years. The coils were also replaced and maybe some of the other electrical components. Pushing the key (activating the choke/primer) will cause the motor to take off and once on a plane will run normally. We have also found out that when one person sits on the front deck it will plane out and run normally.
I have tested the compression on all cylinders and it was between 80 and 90 psi on all which seems a little low to me. I was thinking it might be a carburetor adjustment, but there are no adjustments available. Due to the weight situation with one person in the front I was thinking it might have something to do with the prop. Sometimes when it is first started it smoke heavily. The smoke does have a blue tint, like the oil I am using. When I got home today I pulled the plugs and they all had what looked like oil on them. Any help would be appreciated. Thanks.
