Re: Overboard Safety Switch
Vic Thanks for update.
I hadnt known what a hook was although I had experienced a mild one years ago.
One of the things that got me was that in one accident they mentioned ,two drowned after getting thrown out of the boat, they werent run over but drowned. Shows why wearing life jackets can save you.
It was interesting that the cause of them getting violently ejected was a failure in the steering system. I looked up the case to see what had happened, i had expected it to be a failure of a older style rope/cable system.
http://www.maib.gov.uk/cms_resources.cfm?file=/loch lomond full report.pdf
However when reading the report it showed that it was actually a failure of a hydrallic steering system, seems it had a leak and air got in and it suddenly caused a violent movement in the outboard. I had thought of upgrading my motor to hydrallic steering as it was safer but after reading this and knowing that hydrallic can fail too i think il stick with my cable system and just increase monitoring of it. And also i will check any other boats i go out on for hydrallic leaks. There are a lot of cheap products that come out from asia and are available on line here, not good..........
Ive attached the killcord everytime ive gone out since you originally posted this, its mandatory like a seatbelt to me now.
