can anyone help me with providing the correct steps for testing compression. motor has been sitting for 2+ years and turns over but do not know what else i need to do to get accurate test. this is what i did.
1. new battery connected
2. disconnected and removed all 3 sparks
3. screwed in compression tester in one cylinder
4. turned key for 5-10 seconds
No reading!! Do I need to spray anything in cylinders or add any type of lubricant to get things moving or am I screwed? I have been watching and reading everything and have info overload. What am I doing wrong?
Should i not use ignition....do i use choke or have throttle wide open?
Any help would be greatly appreciated.
