Tilt/trim quit working while out on water. Had to loosen bleed screw to raise engine to install transom saver to trailer home. Trim motor sounds like it is running in the up and down positions. The motor will not raise though. The trim cylinder shafts will barely move if I hold the up switch for a long period of time; but they will start down as soon as I push the down button. The engine will also fall down when I remove the transom saver to the fully down position; but I can't raise it unless I loosen the bleed screw. Any help would be greatly appreciated. Thanks.
