After having let the motor set up for awhile, inside, and having started it, it was shut off for three or four days and put back in the garage. When I took it back out after four days and planned to put it in the water, I decided to test start it again. It blew the fuse when I turned the key switch to the "on" (Acc) position. I have finally determined, by disconnecting etc., that the culprit seems to be the choke solenoid. I disconnected it at the terminal block and tried the switch several times engaging the starter solenoid (with the starter also disconnected) and it didn't blow the fuse. Then reconnected the solenoid and it immediately blew when I turned it to "on." I'm having trouble locating a replacement choke solenoid as it has been discontinued, etc. Does anyone have any ideas as to obtaining one or alternate ways of operating the choke manually, preferably without removing the motor cover?
