Silly Seville
- Dec 5, 2009
- 798
Guys,
Before anyone suggests I get an OEM service manual...I have one on the way!
85ESL69E It starts, runs and idles nice and smooth. Electric shift works just as it should. I am mostly a happy camper. Last issue to tackle is the cooling system. Yes, I have read many threads about this, and yes, I have looked at the parts diagram. Yes, I have put a brand new water pump kit in it, and installed it correctly. I've done near a dozen water pumps on Mercruiser sterndrives, so I'm not new to that game.
Here is my specific issue that I would like to address with your collective help. The water is not getting past the thermostat/vernatherm apparently, as I have taken off the rotten cylinder head hoses, and there isn't a drop of water in the hoses, exits of the thermostat housing or the entrance to the heads. I have the lower unit submerged in a tub of water, so I know that isn't the problem. I have idled the engine until the heads were 165 degrees according to my infrared thermometer.
What temperature does it take to open the vernatherm?
Does it have a bypass that always allows SOME water to pass, or is it an off/on design only?
Does the vernatherm function just like a thermostat? Can it corrode and stick closed?
I'm asking these questions before I yank the thermostat off, since I know I will need several gaskets once I do that.
Final question: If I do tear into the thermostat housing and the vernatherm or the valves are indeed the culprit, can I just run without them; i.e. a wide open cooling system?
Thanks for your answers in advance!
