1991 115hp vro outboard starts and runs great. After a few hours fishing/running/trimming, the starter goes dead and the trim stops working. Here is what has been done to date.
-Vro pump removed/replaced with electric fuel pump/pressure regulator
-New trim motor
-New ignition switch
-New small 20 amp trim fuse
-Wiring/connections all good
Also, the failure is preceded by a low level hot horn whining
-New trim motor
