SigSaurP229
- Oct 1, 2008
- 2,123
In restoring my old boat, I am dealing with some issues of mice chewing through some wiring, specifically the timer base and power pack wires (seems to be the only casualty thus far).
My model number is J115TXCIM.
I ordered two brand new power packs, and a timer base on ebay. The timer base is the right base for my motor, and the power packs are the right packs for my motor as well.
Timer base number 0583376
Power Pack number 0582125
Here is the dilema,
The timer base has the same shape plug as the power packs, however it is missing the black and yellow wire pin (the kill wire). According to my service manual the kill wire doesn't actually run through the timer base it runs from the ignition switch through the wiring harness into the power pack plug. (which makes perfect sense).
I really don't want to cut and splice wires, is there anyway to add a pin into the timer base plug so that everything is basically factory assembled, as I don't want to splice my power pack wires?
If so what part number/tool do I need?
Would I be able to do it with part number 0581656?
Any tricks for removing the flywheel nut since I don't have the specific OMC flywheel holding tool. I have an impact but I am afraid its going to be underpowered for the job.
I started soaking the flywheel nut three days ago with liquid wrench.
Here is the dilema,
