Fulldraw64
- Jun 26, 2013
- 8
Ok the ram cylinder was leaking at top of cylinder so I replaced it and other 3 or 4 seals in there. It was working when I put the top mounting rod through the ram w the the bottom of the unit not mounted. Did this so I could fill it and work it easier without it under load. When I finished put the bottom safety mounting rod in it would not pick the water up or down. I can lift the motor w no resistance and it just falls down. I can hear the fluid bypassing inside or moving around. I did back the manual release valve out more than 2 or 3 turns. Now it won't seat back down, it just keeps spinning. Is this my problem? If so how do I get mrv out after I remove the c clip on outside and is it possible I messed something else up?
Thanks,
Brian
Thanks,
Brian
