Hey guys,
Long time viewer - first time poster. I have learned a ton from this forum and am thankful for all of the time and expertise everyone contributes.
I have question about my 2007 Johnson 15hp - J15RSUA.
I recently tried to rebuild the fuel pump...so I ordered the fuel pump repair kit. As I was putting things back together, I noticed that I was missing the spring that goes along with the air dome support. I do have the part diagram that came with the rebuild kit - but the diagram is fairly grainy though. I am assuming the air dome support is the white plastic dome with a post? I think I am missing the spring that is supposed to be associated with this part which is not included with the rebuild kit. Does anyone know where I might be able to find this part?
None the less, I put the pump back together without this spring. The motor actually ran OK in neutral - but it would not sustain a reasonable idle (in other words, it would "idle" high with a bit of throttle...but as soon as I back off the throttle all the way, the motor would fizzle out). I had 2 new spark plugs, seafoam in new gas with 50:1 ratio. I cleaned the float and carb with carb cleaner, but did not clean all of the jets individually. HOWEVER, I am assuming that my issue may have to do with this missing spring. I am new to working on outboards - I am used to working on dirt bike carbs....I actually had a hard time finding the idle adjustment?
Any help would be greatly appreciated!
