Gene Neill
- Nov 6, 2013
- 21
Title says it all I think. I have a water pump repair kit on the way, what else do I need to order?
Thanks!
Thanks!
If its black partly burnt oil from the fuel its nothing to worry about but it looks like gear oil so the drive shaft seal in the top of the gear case below the water pump has probably failed. (IIRC two seals in there back to back)Title says it all I think. I have a water pump repair kit on the way, what else do I need to order?
Thanks!
The gasket #14Yes, it's definitely gear oil, unfortunately. And the diagram does show two drive shaft seals back to back (#27). Anything else I should replace while I have it torn down?
