Hello everyone,
I have a 1997 Johnson 175 Fast Strike and having trouble with the wiring for the Trim/Tilt at the remote, steering column, and the bow. It seems so simple to just connect the wires, but something is missing. The switch at the remote stopped working so I installed the blinker on the steering column. I just spliced into the wires going to the bow and it had been working fine. I found some corroded wires and decided to replace them, now it will not work at the steering column or the bow. It does work on the engine, I guess I'm missing power somewhere. Tried everything, but cannot get it to work. A bit of help would be greatly appreciated. Thanks
