crankbait cowboy
- Mar 25, 2013
- 570
did the compression test today on it as it had been sitting for years. i squirted a bit of fogging oil in the plug holes and also in the carbs first. the held then carbs wide open . my numbers are 95 on 3 cylinders and 85 on the other. wondering is this acceptable and worth moving on on this unit. also it is very cold here and after thinking about it , it seems that it did not crank over very fast. had good battery on it but thinking maybe bad cables or a dragging starter. my assumption is that this could affect my compression numbers. am i right or wrong, and thanks for any input anyone can give me.
