Re: is 105-107 compression okay for '88 Johnson 110HP 2 stroke oil-injected?
I wouldn't touch it with such low numbers.
even a low compression engine should be atleast 110.
idealy this motor should have 130psi to135psi .
with the numbers you have its worn out, or your compression guage could be out a touch !!!!! try the guage on a good known engine
if they come up low numbers then you will know the guage is faulty.
now are you testing it when warm, with a touch of fuel running through it with carbs fully open ?
if your testing it cold and dry with butterfly's shut the numbers realy don't count, it needs to be done correctly to be precise.
if you have not already bought the boat then walk away and find one with higher numbers.
its ok if you already own it and know how its been looked after and serviced, but to buy with low numbers you could be looking at a lemon that needs a complete rebuild.
and I too would dump the vro ASAP and goto premix.
just my opinion
phill
