I tried to read the code by the cable and i found this code running : 16. Crankshaft Position Sensor (CPS). Intermittent loss of SYNC
i have change the sensor also i tried to adjust it ,, i opend the engine to check if there is any mechanical problem .. still i am facing this problem which is : the rpm not response will in full throtel and the code comes .. please give me the soloution
