I would like to get some insight from the members of this group. I have a 1995 johnson 48 spl that I just purchased. this motor runs great when I let it idle and can even accelerate it with the muffs on. the first time I put it in the water it ran great through the no wake zone at a slow speed. As soon as I gave it some gas this motor pushed the 14ft fiberglass boat at approximately 30 mph. the problem is that this only lasted about 15 seconds and the motor started to bog down. It did not cut off but continued at a moderate speed. I was able to push the key in to activate that choke causing it to run great. I did change out the main line the priming ball but still had the same problem.
I am thinking that this motor might need the carbs looked at but am open to any other suggestions before i take it in to a shop. I am mechanically inclined but feel that me doing the carb work may be over my head. What would be reasonable charge to get these 2 carbeurators serviced at a shop?
Corpus Christi, Texas
