well, i finally got my 1950 johnson TN26 up and running...it still needs some adjusting here and there but at least its running...the one thing i noticed is that it only pumps water at mid to higher rpms...it stops pumping water at lower rpms...would i be correct that the water impeller needs some attention? I think i would like to replace the impeller no matter what just so i have peace of mind...can someone give me some dos and donts to at least get at the impeller for inspection... ill take any and all advise......thanks to everyone for your time and support, sincerely, Brian from Minneapolis
